Originally Posted by DaveRS23
What is it about the leak that makes you think that the housing itself is the problem and not a gasket or seal?
Because the original housing was bent, cut to straighten, welded back. It has 1 or 2 minor leaks. Overall, the leaks isn't bad but my OCD wants to NOT have a differential leaking.
