Even if it’s not something I’d do myself....... I still to like see what other people try, and how it works out for them.
If a particular engine build plan calls for MW heads, then I’m going to use a MW manifold with them.
If I thought the engine could get by with the std port csa....... I’d use the smaller heads along with the smaller manifold.
About the only time I would do the small intake/big head thing is if I were using a head with the std opening/MW sized port..... like an SR or EZ....... where the port opening is std port size, but once you get into the port 1/2” or so, it opens up to MW size.
I would normally use this configuration with “smaller” ci builds, or milder stroker builds for heavier vehicles where the race type MW single plane intake isn’t a good match for how the car will be used.
Nowadays, it’s basically the same sort of decision for someone deciding on whether or not to use TF 240’s or 270’s.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
