Check the plug on the ignition switch. I have seen quite a few melted causing issues. My 77 plymouth had a problem with overcharging and it was a melted blue wire at the bottom of the column grounding out. Plug on the ignition switch? On the steering column is a flat plug. The Blue wire on my sons 1974 D200 was burnt. I cut them out and put a bullet connector inline.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
Posting cheap tech help (CRAP) here since Nov 97, 1000's of posts, some may be good.
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
