Originally Posted by cudadoug
What is the difference that you have seen on a cold vs. warm leak down test?
Discuss.
Thanks!
15% cold after sitting for several days and then warmed up to hot scope
Let us know your results thumbs
Try rocking the crankshaft a tiny bit each way with pressure on it both cold an hot wrench No more than 2 to 4 degree from TDC, be careful while moving IT! twocents
