So I thought as I go back together with my suspension and steering I would put new pitman and idler arms on my 66 Coronet. It has manual steering. So no trouble on the idler arm got a moog part without issue, but the part store say nothing for pitman arm. So I did some looking online and basically the only one I saw was a proforged unit part number 103-10030. Summits site basically says 62-72 B &E body power or manual box so I order one. Well looking at it tonight it’s made different as far as contour vs the original. Sort of looks like it might locate the pivot ball in the same place but hard to say that for sure. Can anyone say for sure? Other thing is with the kick out made on the new part would that effect oil pan or header clearance? Both of my parts I’m concerned with say they fit with factory suspension.2 1/8 TTI hemi headers and Milodon oil pan with side kick out for 7 quarts but no lower than stock pan. I have attached pictures if anyone can say for sure or has any experience I would appreciate the help.
Matt
