Quote
mine finally failed after 44 years Thanks
Soak it in EvapoRust to clean it up. Then pop off the cover and see what it looks like inside. There is a little "tab" inside that rides on the resistor. It could be broken or just worn and not making contact any more. You might be able to fix it.
