You'll want to use the top Port of the 2 above the filter as the top one is post filter and will give a accurate reading. The bottom Port is pre filter, so if your filter becomes plugged for some reason you'll could get inaccurate readings.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
