Originally Posted by moparx
very interesting article ! Thank You ! up
the diagrams give some insight and something to consider.
rigging up a test device of some sort to see what the 3/8 to 1/4 reduction would do, could give me an answer.
i'll have to do a little studying and see what i have laying around in the "plumbing" department.
beer
it will ALL depend on the pump volume & pressure setting you want, a lower pressure will need a larger return with a high volume pump
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
