I have been running the SSBC front brakes since 2007 , when I bought and imported the Plymouth . Had 10"rear drums , were fine till I started running 128+ . Now have rear discs , generic kit using Cadillac type calipers with handbrake , Metric GM caliper . Stops fine without fade now . No power booster .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm
Power by Tex's Automotive
