Quote: The car spun badly the first 2 time runs, my first elimination run it went a 1.45 60', 6.61 at 103 in the 1/8th, i had the mustang beat badly so i let off and go on the brakes hard and went through at 10.49 @ 114. Hopefully in some really good air it will get into the high 20's. My best 60' with the 4.88's was 1.44, the car go's through at about 6500 now.
Your 60's will drop more with better hook. I was hoping to see more MPH but you did hit the brakes, still your only .01 off your best 60 with the 4.88's...not bad for first time out. ..Phill
It went through at 128 my fist time run, but it spun almost sideways off the line, my 60' was1.52 and it only ran a 10.54 that run. I think it will be over 130 mph with a good full pass
