[quote=Al_Alguire][quote=CMcAllister][quote=Al_Alguire]
I meant a component of the Speedwire System (relay, switch, etc). Perhaps I mistook the construction of their stuff as being a sealed unit with none of the parts easily replaced. I am a fan of everything in the car being plug and play, making it easily able to replace anything quickly. Relays, pumps, fans, ignition boxes, etc.
My relays, fuses and switches are all replaceable just like any other relay/switch panel. I like how small and clean it is as well as LED's to tell me if there is an issue, red no power, green all is well yellow a problem with fuse or relay. There are systems that are 100% sealed out there and no thanks. I had a Smartwire from Racepak and once I saw there as nothing you can do if something happens in the lanes or during warm up except wait for a breaker to reset or replace the box I was out.
