Originally Posted by Andrewh
that sounds low for vacuum.
also what is the part number on the master? you say it isn't original, but is it correct?
It is not a Bendex, The one on the car has no casting #. The new one from NAPA also has no #. All I know for sure is the Hemi Master has the lines facing the fender and they use a 1-1/8" bore, so that much is correct. I think I read that the correct Bendex MC with the correct # for a Hemi is the rarest and most expensive MC out there.
