Originally Posted by MikeyT
Hi all,
I am looking to buy a car with a Dana 60. It currently is running a mini spool with 3:45 gears, I am not to keen to running that on the street. What do I all need to convert it to a limited slip Sure Grip set up?
Thanks!
Did you mean 3.54 gears? What ratio will you want?
You will need to know what gear ratio you are going to use and what spline your axles have before you look for a suregrip.
In theory, there is no difference between theory and practice. In practice, there is.
