One spring under dash.
Well I think I'm going to remove the overcenter spring. This Clutch only has 1200 lbs at the moment.........and should go much lower.
Yup, lose it. The overcenter spring actually helps hold the pedal down once you reach a certain point.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
