Thanks Gentlemen,
Right - I've checked and repacked the front bearings during the investigation.
Double checked them, backed off and re-tweaked the spindle nut, the bearings are good, smooth and tight.
jbc,
Thanks for describing the jacking/prybar method to check the lower ball joint, I think I know what to do.
Your goal was to re-create that up/down movement in the ball joint, I'll give it a try in the morning.
I hope I find the answer there.
Cheers,
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
