Originally Posted by hemidart1
Thanks to Gary and Mike (my restoration/mechanic guys) who can make anything work. It took a lot of fabrication to get the carbs, linkage and valve covers etc to work with this intake! The intake was NOS and I really wanted something on the car that would take you back to the old C/FX days of making a 273 run in that class....even though the engine in the car is now a 360.
I can't imagine that linkage working correctly (as in the carbs opening the same amount) when one of the arms (where the links attach) is pointed forward and the other is pointed back. If you say it works, I'll have to take your word for it.
July 19th should be "Drive Like Rockford Day". R.I.P. Jimmie.
