Originally Posted by 500ciDuster
Just did one on an 81 Dodge truck and works great, make sure the module is has a good ground and the 12 volt wire that feeds the module should feed the + side on the coil
The system works by substituting a GM pickup coil and spinning the GM distributor by hand.
The new pu coil will be here today. Hope it's running by tonight!
Thanks all!!!
Milan
