Needed a fuel line from pump to AVS for this '68 Road Runner 383.
Got one from Classic (# MF574A) that's supposedly for this application.
Uh, no way. Even tried 2 tubing benders to tune it, no luck.
Quite different at the lower area, as far as bends & angles, hits block, alternator, & distributor.
I have an original to compare it to but the carb end was screwed up by someone, hence the aftermarket Russian Roulette.
The Classic catalog also lists an MF571A and MF572A.
The 571 says for AFB but looks the same as the OEM piece. Also looks like Inline Tube # PRE6801.
The 572 says for AVS but looks more like the 574.
Anyone here know the secret part # or if the AFB uses the same thread as AVS?
