He can take the vin and run it at the dealer. That will give him the rear ratio. One thing he could do is start running a cleaner through the fuel. It may be a sticky injector. might take awhile. He could drain the fuel filter can, replace the filter and fill with cleaner. Then run the truck.
“So if it’s on the internet it must be true”
Abe Lincoln
