I did not cut the shell of the plug off yet to read that. I was running 36* total timing til I pulled a plug and seen it speckled, I then reset timing to 34* for the rest of the runs. It did slow down .5mph on next run set at 34*. The specks look to be brown in color. The color change on the ground strap was right on the bend with 36* timing.
