Re: 70 Challenger, no gas, oil pressure or water temperature
[Re: Sammy]
#2688817
08/17/19 05:52 PM
08/17/19 05:52 PM
Posts: 1,715 central il.
second 70
central il.
Anyone got a picture of a 1970 Ralleye Dash voltage limiter? Sammy also check this link on ebay. https://www.ebay.com/itm/Cuda-Chall...el-Mopar-Instrument-Cluster/283494246527 For some reason I can't copy the picture but look for the one that shows the back of the dash. It doesn't have the limit switch installed but if you look at the picture you can see two bumps with a hole between them this is where it mounts. (Notice the two bumps on the side of the limiter picture I posted). Right next to hole marked DBL. In the picture it's on the bottom but in car it's the top. Hope this helps, Mike
Entire Thread
Sammy
08/17/19 04:46 PM
VCODE
08/17/19 04:52 PM
Sammy
08/17/19 04:54 PM
On the edge 02
08/17/19 05:04 PM
Sammy
08/17/19 05:59 PM
stumpy
08/17/19 06:04 PM
Sammy
08/17/19 07:36 PM
AARCONV
08/17/19 07:37 PM
Sammy
08/17/19 08:18 PM
Sammy
08/17/19 08:24 PM
stumpy
08/17/19 08:39 PM
On the edge 02
08/17/19 09:40 PM
stumpy
08/17/19 10:24 PM
On the edge 02
08/17/19 10:29 PM
second 70
08/17/19 09:26 PM
On the edge 02
08/17/19 09:36 PM
second 70
08/17/19 09:52 PM
On the edge 02
08/17/19 08:00 PM
Sammy
08/17/19 08:15 PM
RapidRobert
08/17/19 08:35 PM
