If you are on a budget build I am assuming you aren't trying to squeeze every last HP out of it. If you find no other problems with the pistons/rods, the real question is, "how much taper do you have?". If you have minimum taper (<0.005") I'd break the glaze, rering it and run it.
"We live in a time when intelligent people are being silenced so that stupid people won't be offended".
