You can’t take it apart. Just drill a hole in the outer case in a place that you can easily access a grease zert. Then you can clean out a lot of old grease in parts washing fluid. Install the zert and grease away. I think Detroit Muscle technology sells a kit with gaskets, zerts and instructions.
