Just got the six pack/carbs mounted on the 440 in the car (70’ Bee) for the first time. With the air cleaner and cover on there’s interference with the hood, raises the back of the hood about 1/2” when it’s closed. Intake is an Eddy CH6. Is this a taller intake than the stock cast one? Does anyone have dimensions for big block six pack intakes?
The RB intakes are the same height "factory" or aftermarket replacement, I'll assume you have the twin scoop hood?, and not the powerdome?, is the air cleaner hitting a brace under hood?, running an under hood pad?
Mike
