Now that the rear frame rails are patched, the next task is trunk floor pan removal. A previous owner used an acetylene torch to cut out pieces of both passenger side wheel houses in order to scavenge patches for another charger. Again, this car was parted out before aftermarket sheetmetal was available...but it's still a bummer considering how solid the driver's side wheel houses are.
I fired up the compressor and got out the sheetmetal trimmer. I use it to trim around both sides of every frame rail edge. This leaves just a thin piece of sheetmetal along the lip of each frame lip. It took me about 3 hours to get the big pieces out and get to this point...
And the pieces/debris that came out...
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
