Originally Posted by topside
On my 512 I wanted vac advance for street use. Had a Firecore which was OK but didn't have vac.
Went with an FBO-reworked MP distributor with their plate in it & set for 20 initial, 36 total.
Perfect, lit right off cold or warm, zero issues, spot on.
Do you think they could set one up for say 23 initial and 31 total? My car likes all the timing it can get at an idle...I tried a locked distributor with a retard...it never worked on the first try...Was going to break a starter or worse.
'70 Cuda,...605 EFI Hemi Street Car (6.20 best pass, 1.33 60ft)
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.25 at 108.75mph from inside car)
https://www.youtube.com/watch?v=3zQEb9uxFng (6.25 at 108mph from outside car)
'66 Barracuda AWB Stretched nose Blown 440 Car in build stage
'71 Duster Drag Car 400 Low Deck 512 best 6.002 at 115.44mph
https://www.youtube.com/watch?v=Znuo3jMUXTk
