Originally Posted by fast68plymouth
The Hellcat doesn’t have the extra IAT cooling provided by the A/C unit like the Demon does...... but it does untilize s a pair of intercoolers.
Doing a little digging.......
Quote
The goal is to reduce the temperature of the intake air to less than 140 degrees Fahrenheit so the water and antifreeze mixture is maintained at about 100 degrees F.
Supposedly they can run flat out for 20 minutes before the ECU dials things back due to heat. Probably pretty close to out of gas at that point also lol
68 Barracuda Formula S 340
