The early carriers, pre 1962 had a different casting numbers on them but the specs. on the pinion races are the same as the 741 and maybe the bigger 742 cases is what I have heard on here, maybe not as I have not had hands on experience with none of them confused
The 2.76 up too the 6.17 gear ratio will fit in the carrier there made for up
