Not the return line and is on the other side of the truck where the fuel lines run, you could just use the tank pump too but should be regulated but I was messing with mine a few years ago and made an aluminum adaptor for one of those old 318 2bbls which worked and it ran as good as the TBI, I just rigged the fuel line so it was using the returned and it never did over pressurize the float.
