Are switching speedo gears the only reliable way to adjust an inaccurate speedo?
I used the calculator chart above to get an estimate of 27 teeth I should need with 225/70-14 tires and a 2.76 rear diff ratio.. I'm coming up with 6.2" sidewalls, plus 14" rims = 26.4" tire diam. With a 2.76 diff, the result is 27 teeth for the speedo gear.. is that how it works?
The speedo in our '65 with cable-shift 727 automatic is indicating about 10% too fast (reads 90mph when actual is more like 80). I'll pull the current gear and compare number of teeth in the car..
Thanks, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
