How many rpms were you running at the time you hit it... MOST times
when a sprag gives out is when you get off the pedal then hit it again..
I blew a rear end in the race car but it didnt hurt the sprag.. I pulled the
trans for a check but it was fine.. the getting back on it after letting off
is what can hurt it... its that slap of the rollers that can break the roller
case.. in a manual VB its hard to tell if you cracked it.. pull it now while
you have the time... good luck
