Originally Posted by MadMatt
My 1998 Dodge Grand Caravan Sport with the 3.3 has an electrical issue. It starts and idles fine, but when when the RPM gets above 2300 the battery light comes on and the LCD dash displays go out. Any advice is appreciated!
My fuzzy memory seems to recall those year minivans have a cold solder joint in a ground wire to the instrument panel that is a common problem.
