It's called a relay but doesn't look like a traditional relay. I'm not sure exactly where it is on a Dakota but I normally find them bolted to the core support or frame rail behind the bumper, fascia, or headlight.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
