it's a captive washer bolt
Hi Bill,
The bolt I'm referring to is not the adjustment bolt for the belt tension but the lower bolt that passes through the slotted bracket and the triangular bracket securing it to the engine. Again, the book says washer but the drawing says no, drawing shows washer on the bolt that goes through the heater hose bracket, triangular braket and alt. spacers. Thanks again.
