You're in good shape pressurewise. Brakekleen the area clean & see if you can see it weeping when running otherwise you might pull the dist/intergear & preoil so that way you can spot it easier when it ain't running. first turn the dampener to line up a tooth with the magnet before pulling the dist to make reassembly/restarting easy.
