Originally Posted by Cab_Burge
You need to lean down the primaries on the side of the carb. that feed the dark colored plugs
On a dual plane intake the primary feeds two cylinders on each side.
On a single plane, they both feed all 8.
Only time I ever ran into all plugs on one side being "dark" was an intake leak.
