We're working on a 360 block with Comp hyd roller lifters and some of the lifters are exposing the oil gallery at full lift. I looked in the Morel catalog and their pictures show a full shroud around the wheel. Just wondering if anyone has run into this and if the Morel lifters solved the problem. I can order a set to see if they work but thought I'd check to see what others have done.
