Originally Posted by mopower440
Originally Posted by topside
Had a Champion 26" in the 512" Duster, in its stock 22" opening, and with a mech fan and a shroud, cooled fine (175 tops) with no problems.
Have a Griffin 22" in my SB Duster drag car (half-filled block, 18" elec puller, no shroud), plenty adequate; it likes a coolant temp of 120-130 staging. Might see 160 or so on the return road.
Zero leaks or problems with either radiator, and the Griffin's been in there since around 1996.
Looking at that ECP site, the radiators look like pretty screamin' deals if you don't need the electric fan setup.
My only reservation with alum radiators is the non-OEM look in an otherwise restored car, but for hot rods, no worries there.
How did you bolt the bigger 26" radiator in place of the 22"? Did you just drill new holes in the radiator support and use nuts and bolts through it or?
That's gonna be my plan but I may use nut-serts just for ease of assembly. Looks like I will be going with the ECP Speed Cool 22" it looks like the best looking radiator of the bunch around $200 that has a mounting flange for a factory type shroud.
Thanks again guys for all the input thumbs Seems like every tech article I read about cooling they all say 2 large tubes are the best option for my application.
Gus beer
64 Plymouth Savoy
493 Indy EZ's by Nick at Compu-Flow
5-Speed Richmond faceplate Liberty box
Dana 60
