The adapters for the hurst as funky. They raise the shifter up. I may be able to get a pic later. I'm trying to get my transmission together for my Barracuda so I'm inside looking up info. The bolt on handle was always better than the bayonet style, but we have used the bayonet style to bolt the handle on (drilled/tapped handle, drilled mechanism). This may use the standard Hurst adapter, but I'd have to have one in my hands to compare as my son's four speed is on my bench...
