I use an AEM AQ1, I can log 8 channels plus it has a CAN to BUS input. I log the following: Fuel Pressure Oil Pressure Crank Case Vacuum Oil Temp Trans Oil Temp Drive Line Speed RPM G-Force Trans Brake Release On the CAN to BUS the following: AFR Right/Left 8 EGT's
