dvw...
I had used a 68 Charger 8 3/4 rear and transmission I had from a parts car.
When the 70 Satellite was put together I wasn't aware of the difference between the NSS switches.
The comb in the valve body is wrong for the 3 pin NSS I put in the transmission once I found the 3 pin connector while hooking everything up.
The early comb in the valve body with the 3 pin NSS made the back-up lights stay on in D-2-1.
I wired them through the Aftermarket floor shifter and didn't worry too much about it...
At some point I'll have to correct everything if I ever have to pull the transmission...
In the end I could just have a bad relay...
![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
It still does it in about 1 in 20 or so start ups...
![flame flame](/ubbthreads/images/graemlins/custom/flame.gif)
