It shouldn't be that tight. The spring in the fuel pump might have a hard time keeping the rod against the cam lobe if it's too tight and it could cause premature wear or even lock the pushrod up from friction. Plus at higher engine rpms with it tight you could experience pump cavitation resulting in low fuel pressure and low volume.
I love the smell of Deer guts in the morning, it smells like... VICTORY!
