Originally Posted by rattler
I can't remember, is there a return line coming off the fuel rails? If not how did you route a return line?
Factory rails do not have a return fitting. It's not uncommon to run a regulator near the tank. That setup makes for some fluctuating fuel pressures, but it is at least consistent fluctuating that can be tuned to.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
