Do you know anybody with one of those flexible bore cameras, or whatever they are called? Might be able to get a view through the drain plug to see if the parting lines in the crank are thin (cast) or wide & flat (forged). Maybe even find a number on it.
It might depend on just how it was balanced if rebuilt as well. Internally with mallory metal, with OEM weight parts or aftermarket, etc. Might need a counterweighted flexplate too if its all not "neutral". Bore scope - not a bad idea. I think I know someone who has one. It's a 4-speed and I'm told that the car should have a 10.5 inch flywheel with 2-holes drilled all the way through the flywheel next to one of the flex plate mounting bolts (thanks Wayne from Brewers!) since its a V code and should have the heavy rods. I will check for that also.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
