If your not using the BB Chevy rod journal sizes and Chevy type steel rods and you are using the stock type Mopar rods you may have a problem with the block clearances and the stock type windage tray clearing each other
Assembled carefully and inspect to make sure, grind as need for clearances
Not sure of the difference, but the 505 stroker we are doing now seems to have slightly more clearance than my old 505. Only difference is H-Beam Rods vs. I-Beam Rods?
On my 400 block stroked to 500", windage tray clearance was easy because I'm using a main cap girdle which lowers the windage tray the thickness of the girdle.
