340 Ed Hamburger oil pan from 1989 -
Hey DusterW2,
Been searching for info on these old pans and cam across your post. I have that oil pan on a 69 340 that was in my Cuda when I purchased it. The dip stick was hand scored for the oil level. When changing the oil, it takes over 8 quarts to get to the dip stick marks. Do you know what capacity or what was run in the engine in the photos? The pans I see on the market now are 7qt. I'm concerned about too much oil and causing windage.
Thanks,
