Originally Posted by Greentween
Just so you know the brass chevy valve, PV2 or PV4 are nearly a bolt in swap. Only one adapter is needed if keeping your stock lines. You can either remake the rear brake feed line from master to the PV or use an Adapter in the PV to accept the stock line fitting size. You can grind off the bracket from your old valve and reuse it to mount the new valve on to the inner fender stock position.
Interesting. AC DELCO 172-1353 (disc-drum) and 172-1361 (disc-disc)
