In the OP of that car.. it did not burst.. if its alum line the builder failed to put enough clamps on it.. alum line shouldnt have movement or vibration on it... if it did leak it was due to a crack in the line and/or a crack at a fitting(where it was flared.. a line that has a double flair is more susceptible to cracking right where the flare folds back on itself)
