Originally Posted by Billy
There is alot of slop between the servo piston and the adjustment arm (rear). Could the piston be stuck?
If it is stuck it can cause the reverse problem but not the third gear problem. Also would have no eng braking in low gear but it sounds like you have more then just a low/reverse servo problem. I agree it needs to come out. Ron
