Originally Posted by Andrewh
If I am pulling the axles and putting them back in the same rear end, if I don't mess with the back lash adjustment, do I need to check anything? {Yes, you should recheck the axle end play}
what happens if it is off? {Too tight or too loose, accelerated bearing wear}
8 3/4 with a 742 one-legger. {Doesn't matter}
"We live in a time when intelligent people are being silenced so that stupid people won't be offended".
